Kubota L2650 hydraulic pump
Badnewsbeers
Kubota L2950
Dec 11, 2023
Peebles, Ohio
I have just rebuilt my hydraulic pump on my kubota L2650 because the main bearing seal was bad and was leaking hydraulic fluid into the crankcase. Once putting the pump back on the tractor I now have no hydraulics or power steering. I have tried turning the wheel back and forth multiple times while running at higher rpm’s and still can not get loader or 3 point hitch to work. Please help.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
642
255
Herald Calif.
You will need to prime the pump. Take the inlet pipe off the pump and fill the pump with oil. Should pick it up and start working.
