Hey guys. I finally got the PTO lever to move to hi and low as it should and the PTO works fine. The only problem I am still having is that the PTO can't be engaged while the tractor is running, I must crank the tractor with the PTO already engaged. Don't like to do it this way but it's the only way I can use the PTO. I'm still trying to verify if I have a two stage clutch. If I do, it is not working/adjusted properly. Does anyone know if all these tractors have a two stage clutch and if not what is the proper way to use/engage the PTO? thanks
