Hello, am new to this site, and also owning a tractor.
I found some related threads to front axle oil changes, but am a bit confused, hopefully someone can help.
I actually own a L1801DT, but from reading a bit I think it is very similar to the L185DT.
Front axle oil specs say: (from: https://www.tractor-specs.net/kubota/kubo-l185.html)
Front axle differential case(4WD)
1.1 L (1.16 US. qts., 0.97 Imp. qts.)
Front axle outer drive case (4WD) – each
0.8 L (0.85 US. qts., 0.7 Imp. qts.)
First question: I was able to drain the oil from both outer drive cases, and the diff case.
the fill plugs for the diff case appear to be the two large plugs on top of each front axle housing... hard to miss those. When I fill into them, it drains out of the middle diff case drain plug. But where are the fill plugs for the outer drive cases?
Images below are rear and front views. My finger is pointing at the drain plug. Could someone please comment on where I can find the fill plug?
Or are all the cases connected, and use the same 2 fill plugs on top of axle housing? After driving for a bit to distribute the oil, I checked both outer case drain plugs and nothing came out, so either the oil hasn't distributed for some reason, or there are seperate fill plugs.
Is it possible to overfill these cases?
Thanks a lot in advance
Ben
Ben
