Kubota l1500 Oil Light
adegas
Kubota L1500
Dec 31, 2012
Portugal
Hello everyone, i have a L1500,and..i would like to know the meaning of the orange light (OIL) on the dashboard, has to do with the pressure of the oil or the oil temperature, i already changed the oil but keeps flashing when the tractor warms.
Thanks
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Thanks
Did you just buy the tractor,did it have low pressure and thats why you changed the oil.When you changed the oil did you also change the oil filter with one that has the correct relief pressure?
The oil sender may also be faulty so you need to screw in a good mechanical gauge to check.
dave
adegas
Kubota L1500
Dec 31, 2012
Portugal
i have the tractor for about 11 years, and only the light flashes a few months,every year i do the revision, so now I opted to just change the oil, I noticed that the light takes longer to ignite, but at the end the result is the same, i still do not know what it is the means of the light, possibly is the only the valve that is defective
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
The light on means you have low oil pressure. Or, a bad guage. There is another person on here that is dealing with the same problem. Read his problem and all the answers.
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Whew. Dodged a bullet there. If you get low oil pressure when warm that's a sign the main bearings have reached their service limit.
