i have g23 when i engage pto she loses i got bad diesel got injectors redone great power when pto not engaged she goes for about half an hour before starting toplay up will cut well when turning and going opposite way lose power when ptoengaged
It takes little power to start or drive a tractor. Using the PTO takes a great deal more. Disconnect the fuel line near the tank and try to drain fuel into a container. The flow should be steady and not diminish. If you only get a dribble you may have a blockage in the tank. You may also need to replace the fuel filter then bleed air out of the lines.
she seems to go great for about half hour but starts lossing power she will drive up one side then when you turn and go other way she drops in power i cut football pitches its very level
