I have a 2015 Kubota L3301 Tractor. Will crank but wont start. Sounds like no fuel getting to engine at all. Checked all fuses they are fine. Drained tank, unclogged the screen filter , it was sticky so i did have some brown tar at just in the screen not in the big fuel filter. It wasn't pushing fuel through the small silver fuel pump. Cleaned it all out and fuel starting to flow fine, installed new fuel filter, unscrewed 10mm bolt at top and got all air out of lines, fuel flows good. Still no start. Removed fuel shut off solenoid to test. Line is getting only 11.5 volts when key is turned on, then 12 volts for a few seconds when key is turned off. solenoid doesn't seem to click when key is turned on but vibrates in my hand for 3 seconds when key turned off. It doesn't have a plunger I can see must be a new design. Fuel pours out of hole where solenoid was when i turn key on. If i put my finger over hole i can feel it building up pressure when key is on. Holding the solenoid unplugged in my hand i put power from a test lead straight from battery to one side and neg to other i can feel it nock in my hand. I cant see anything move on solenoid by looking at it but its all happening inside the solenoid so its impossible to see it. Not like the old plungers that just pull out and in. How can I tell if its bad or wire is bad. Or is the problem with the fuel injectors perhaps getting clogged with bad fuel?
