Will a Kubota 1640A loader that was on a B1750 mount up to a B7100/B6100/B5100 etc? I'm wondering if the mounting subframe would bolt up. I'm not sure if the drivetrain (under side) of the two series tractors are the same or not. Any ideas?
Hi Tiger. I had a 1640a on my B7200 and put it on my B8200. It took a bit of fabrication but it works well. The frame on the 8200 was different than the 7200. If you are up for a little fab work then the frame mounting is no big deal. If you are not then you are right in making sure they will swap. I kind of doubt that they will, but kubota may have a subframe kit? Maybe Vic or Mr K will kick in on this. Dusty
