Kubota F3680 Engine Stops After Random Intervals
8,802
No sputtering just straight off. The unit randomly shuts off, could be just sitting idling after working for a few hours or 5 minutes after its started. i have tried to pin it down if rough terrain causing this issue and there hasn't been any commonality. Sometime the machine will fire right back up and other times it can take more then a few attempts to fire back up.
Have you replaced the stop solenoid?
Mark_BX25D
Bx25D
Jul 19, 2020
1,782
1,302
You need to monitor whats happening at the 12v input to the stop solenoid.
A 12 light bulb temporarily wired in parallel right at the stop solenoid will tell you what's happening.
You could do the same thing with a meter but that's harder to monitor while you are driving.
Stop throwing parts at it! TEST!
Forget about compression. Lack of adequate compression does not cause the sudden stop you have described.
JohnR68
F2400 Mowers
Dec 26, 2024
QLD Australia
I'm having what i think might be a related issue with my FS3690 and Id certainly appreciate some tips. I went to start it this morning and forgot to have the parking brake on so it wouldn't crank. But then I impulsively hit the brake pedal before id released the key from the start position and the starter momentarily cranked. After that it wouldn't crank at all. I thought I might have damaged the brake switch contacts by making it under load when i pressed it with key in crank position. But Ive tested it and it seems good. I also tested the other two switches, seat and PTO, and they seem good as well. However after testing the switches and re connecting them I'm now getting what seems to be an alarm, the horn blaring constantly and a red light on the panel whenever i turn on the ignition. I don't have a wiring diagram for this thing and I can see one in the wiring diagram thread, but if anyone can provide any insight into the electrical system for these that would be great.
JohnR68
F2400 Mowers
Dec 26, 2024
QLD Australia
I figured out the issue, or two separate issues, one might be relevant to the original posters question about the machine randomly stopping. I think when i was testing the switches I've shorted something out because i found a blown 5 amp fuse. After i replaced that the constant horn/alarm stopped but still no cranking.
I'm only a little guy, 63kg (138lb), and it seems like i'm not heavy enough to always activate the seat switch. Up until yesterday I was always sitting on the front edge of the seat, because it was seized in the furthest back position and i never had the cranking issue. But yesterday I got around to freeing up the seat sliding mechanism and moved it to a more comfortable position for my short legs. Now when i'm sitting further back in the seat the switch doesn't always seem to activate. For the guys who were having the intermittent stopping issue, could it be that the mechanism for triggering the seat switch is somewhat temperamental and its switching itself off at random times depending on your sitting position?
TimAT
GF1800 4x4 60" Mower
Oct 5, 2023
41
Kansas City. MO
I'm late to the party. My GF1800 went thru a bout of not starting, randomly dying, but eventually starting and running fine- until it quit again. Checked the usual suspects, (safety switches, etc.,) Gave up and started going thru the wire harness, checking end to end continuity and finally looking at each wire for damage. Didn't find a thing. Finally pulled the fuses. Found the one for the fuel solenoid was pretty well corroded on one of the blades. Replaced the fuse, (It was good, but they are cheap) and washed the fuse block with a good electric contact cleaner. No problem since.
Mark_BX25D
Bx25D
Jul 19, 2020
1,782
1,302
Corrosion causes confusion.
It can make a circuit look open, OR closed, depending on what you are doing. A continuity test with a meter can show a good circuit when there is corrosion present, but once you put a load on it, it can act like an open.
Good job finding it! (y)
