Kubota BX2380 Leak
Jeff E
Kubota BX2380
Oct 1, 2023
Covington TN
I've a leak in the neutral lever, and it's easy to access but can't remove the assembly due to the 4 wheel drive shaft. Not for sure if just the 4 wheel shaft can be removed or one has to take the whole front of the transmission of just to remove the neutral lever assembly.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,185
877
PNW-WA
Assuming you can not get a typical wrench on the hydraulic line, you might find a junk wrench. Put it in the vise, heat it red and bend as needed.
4,886
if you mean oil drips from where the high-neutral-low range lever is, #060 are Orings, that should be easy to replace. Maybe explain better WHERE the leak actually is.
