Kubota b7500 3pt hitch not working
kubota dan
Kubota B7500, box scraper, front loader, rake
Mar 22, 2026
North Carolina
Need some help. i installed a new vevor 2 spool valve on my kubota B7500HSD the dump and tilt work fine but my 3pt hitch is NOT operational now. Fluid level is good, knob under seat is ON. The Power Beyond line is hooked up to the N port on the side. i have read on here about a PB sleeve is that what i'm missing? just doesn't make sense. Also not sure how to bleed the 3 pt line system if that is the case. pressure is at 2300 psi
thanks
11,163
Yep if you didn't install a PB sleeve then that is 100% your issue.
Go to where you bought the valve and see if they have the PB sleeve for it.
7,320
thanks
It majes perfect sense. That is "wrong" but the loader should work. You dont have to bleed anything. Where is the "power beyond hose going and put a plug in the T port.
kubota dan
Mar 22, 2026
North Carolina
Ok I ordered one, so am I putting it in the T port or the N port? I right now have the PB hose line in the N port.
kubota dan
Mar 22, 2026
North Carolina
Just want to thank TheOldHokie and North Idaho Wolfman for the help in getting my 3pt hitch working again after switching out my control valve. This is the correct PB Sleeve that fit the Vevor 2 Spool Valve. installed in the N port.
thanks again glad i found this forum to talk too.
P40 Hydraulic Control Valve & Log Splitter Valves Accessory G1/2” for “N” Port Power Beyond Adapter Plug
