Kubota B7200-HST-D - HST Suction Strainer Filter
ttj49
B6100-DT
Got the parts, service and owners manual, and so far, I've determined this is the part I need. It's Kubota part number 66204-36210. Should I also replace the O-Rings?
I want to replace the strainer that's at the end of the HST suction pipe. Just wondering if I've found the right part. Also, is there more than one hydraulic strainer on this machine other than the primary hydraulic filter? Thanks in advance for any knowledge.
rparkinson
297
Northport Maine
Yes that is the only one on the machine. I dont know that I would replace the screen, just give it a good clean and spin on a new hydro filter and fill it back up-
cb750k8
B7200HST D 4X4
Aug 23, 2013
101
Dublin, Ireland
There are two filters/screens. One on the HST system located on the left side of the tractor and one on the Hydraulic Lift system located on the Right side.
Part no of Hydraulic lift system is
66611-36120
I had both these out recently, inspected them and felt they did not need replacement.
Yes change O rings.
Hope this helps.
ttj49
B6100-DT
66611-36120
Yes change O rings.
Hope this helps.
Right on target, Thanks...!! I found both of them.
