kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
HI
Ok jacked up the front of the tractor greasy oily mess drips onto the ground.
I was going to check the oil in the reduction gear box at the wheels but apparently the seals for the ball pivot are no longer any good.
There looks to be two metal retainers one outside and one next to the gear case. Can these be reused; as they are looking pretty pricey.
Then there are holder seal 1 and seal dust cover and packing felt and dust cover 1 and 2?? Number 12 and number 14 look like metal that can be used over?
Next comes the bad part If I look up everything for a b6000 it is different numbers than a b7100. Which would possible fit the b7000 I am working on?
Not to mention the bearings and play in the rf wheel hub
