Kubota B6000E Belly mower
Berniew
Kuboto B6000E, Woods 304K mower, Massey Ferguson 135, Fleming flail mower
Apr 13, 2023
61
14
UK
Hi there, I have a recently started working on a Kubota B6000 E tractor with a belly mower, which runs off a front PTO. I am unsure how the mower is supposed to be attached as when I removed the front PTO to fix it I had to also remove the plates at the front which held the mower deck. I then disovered that the only thing holding the mower to the tractor was a bit of rope at the back of the mower. Can anyone identify this mower for me and give me any advise, diagrams or pictures as to how it should be fitted? I had to take the PTO off as the owner kept hitting things and broke the shaft (seperate thread on this site) and I assume this was because the mower wasn't at the correct height. Any advise greatfully recieved. Thanks in anticipation. Bernie
TSmith2670
BX2670, B6000
Dec 28, 2015
27
10
Hummelstown, Pa.
Look at the attached manual. This will get you started. Many of the parts are not available anymore for this 40 year old machine but Messicks can get a few of them. I din't use mine anymore because it's a pain to remove. I use a Woods 3PH mower. Much easier to remove if needed. Good luck.
Berniew
Apr 13, 2023
61
14
UK
PM me and maybe I can get you the file needed. I can't upload the whole file. It is too large.
Thanks for the response. I will send you as message but if you don't get it, I am new to this Forum and haven't found my way around yet, do reply to this. Thank you in advance. Bernie
