Kubota B6000 Clutch Adjustment
emeded
Kubota B6000
Mar 11, 2022
Roseville
I just got me a nice new to me Kubota B6000. I love this little baby tractor! Starts up as a brand new one! It's in decent condition for it's age, but I do have a little bit of an issue with the clutch. It works fine, but I have to press clutch pedal way way down in order to disengage the clutch properly. I tried to adjust linkage under the clutch pedal, but that did not really give me anything. Is there a different way to adjust this? I checked owners manual and service manual, but they are just talking about pedal adjustments. I see there is an opening under the tractor, but not sure if there is a way to adjust this some more.
Any help would be appreciated!
Thanks!
8,278
#1 the clutch pedal should never go that far down, so the stop on the linkage is messed up.
If you need to push the pedal farther than an inch or two of travel to get it to disengage, you'll need to split it and put some parts in it.
Clutch plate, pressure plate, throw out bearing, and pilot bearing.
