kubota B2100 HSD lift arm control lever problems
rifle44062
b2100hsd
Apr 11, 2019
Southington, Ohio
I have no power going from lift arm lever to hydraulic system that controls 3pt arms. It has something to do with part number 090. Lift arm is just loose. Can not raise or lower 3pts. Does anybody have any experience with this? Thanks
Captain13
Feb 27, 2019
520
170
Kathleen, GA
Is the speed adjustment knob under the seat adjusted all the way out so you have no pressure? Check that. Sometimes your turn it with your shoe or something and you have to adjust it so the 3 pt will work.
9,274
Yes the lever is not turning the rod going into the pump.
WHAT? :confused:
Captain13 asked you if you have tried turning the drop speed knob under the seat.
The knob and control goes to the front of the cylinder not the pump, the hydraulic pump is on the side of the engine.
But lets back up a little, is this a new issue, like it was working then all of the sudden stopped?
Does it have a loader attached or was a loader removed recently?
When was the last time you did a fluid and filter change.
9,274
Use words?
Because just saying a part # is not helping us help you.
