kubota 4350 front end
haflinger
kubota 4350
Jul 5, 2012
Royston, Ga, USA
I bought a kubota 4350 that was used in a hog lot and basically has rotted out the front wheels from the hubs out. I found an L2900 front end yesterday which has the same size wheels (7.00x16") as my 4350. Is there any possibility that the wheels from the spindle out would interchange with my 4350 front wheels. No one at Kubota has been able to give me any advise. The 4WD on my 4350 works fine and the gears are fine - just pours out fluid and squeaks. The prices Kubota has quoted me to replace everything inside the wheels is astronomical!! I'd be greatful for any advise. Thanks
bcbull378
GL3830,fel,brush hog,pallet forks,disc,gannon,auger,springtooth,plow,drag,ripper
Sep 6, 2011
579
32
Ventura Ca
Just my opinion but it sounds like your local Kubota dealer isnt being much help. I would think they could pull up the parts #s for both front ends and see if they match if so bingo your good to go . You may be able to pull up the parts #s yourself, Im sure someone on this forum can help you I havent had a question here that hasnt been answered. Good luck ......Dan
Bluegill
Jan 11, 2012
1,559
Success Missouri
I believe the front end on a 4350 is goin to be larger and beefier than an L2900.
Messic's is good folks to deal with and have been good help to me on the phone. Course my local dealer has been also.
haflinger
kubota 4350
Jul 5, 2012
Royston, Ga, USA
Messick's straightened me out on this one - it won't work. Anyone got the complete set of front end wheels from the hub out? Thanks for all the help!!
