Kubato L2550 need help
mikesavage
summerfield,nc,us
Tractor will not start. No dash light. No power. Have replaced battery, battery cable, ignition switch, all fuses, one buss fuse. Starter has been checked and is good, still no power. Safety switch at clutch pedal good. Any help will be greatly appreciated.
PHPaul
Apr 2, 2015
979
876
Downeast Maine
www.eastovershoe.com
Battery ground? Power lead from battery to dash (sometimes that is connected at the battery cable lug on the starter)? Wiring harness plugs seated?
rentthis
1,004
23
38
summerville,sc
you replaced the battery cable. Did you change one or both. If you didn't change the ground cable, you might have a ground problem at the frame. be sure it's clean and corrosion free where it bolts to the frame. . With most other problems, you would likely have dash lights.
5,615
Did you check replace the main fuse link?
It's around the starter, it's connected to the #10 wire that comes off of the same connection as the + battery cable on the starter.
turck
m5140, JD2020, ford 850, farmal 240
Apr 20, 2013
56
carthage, ny usa
Did this happen all at once or was there any symptoms before lights out? I have found more times than not its usually the ground. Try running a temporary ground with jumper cables from battery to good ground. If that doesn't work get a voltage tester and start tracing.
