KUB206 or KUB215
sandiegomark
B6000 B206 FEL, Gannon box, hauling, loading
Apr 27, 2019
12
SPRING VALLEY
my b6000 FEL cylinders are leaking badly. Anyone know source for replacement cylinders. KUB044 and KUB045 I believe these are the cylinder numbers. Thanks for helping
9,171
Leaking cylinders usually just need new seal kit installed, if you don't want to do them yourself, your next best bet would be find a local or semi local cylinder shop and have yours rebuilt. ;)
sandiegomark
Apr 27, 2019
12
SPRING VALLEY
hello, thanks for the response. do you know the seal kit number or where to find the right seal kit?
shootem604
Apr 23, 2018
874
British Columbia
You may not even need the Kubota seals - your local hydraulic shop probably can replace them with standard off the shelf seals.
sandiegomark
Apr 27, 2019
12
SPRING VALLEY
Re: KUB206 or KUB215 seal kit
Hello shootem604, thanks for your response. I noticed on one of the older post on the forum that a newer backhoe cylinder had the same seal kit that my FEL calls for. That would be huge if all the 2" cylinders that Kubota made could use the same kit. Coleman, Messick's have them for about 20 bucks. Thanks again, San Diego Mark
shootem604
Apr 23, 2018
874
British Columbia
I depends on who made the cylinder. My backhoe was built for Kubota by Woods and they used Energy or Lantex cylinders - luckily both used the same seals, but no so for my made for Kubota Arps built FEL cylinders.
