Kabota L3010 HYD
LadyRancher
Kabota L3010
Aug 16, 2024
Arizona
There is a leak, at the small square box (see pic) NO ONE has been able to identity it or fix it. Seems simple. What is it called? Kabota told me to buy a new trans (totally unneeded!) rather than fix the leak from where someone removed this box (not me!) I reinstalled it, but it still leaks. I made gaskets, used permeated etc. also the center nut in the middle of the box leaks, not sure why, looks to have a purpose. Top LF in PIC, 4 Corner Bolts and One in center
7,488
First off, you must have a chinese knockoff "Kabota" as we only deal with KUBOTA's on here. :ROFLMAO:
Is this the small square box your talking about (purple)?
If it is that's the (regulator).
Where is it leaking, blue, green, red?
This is the whole part:
And caution that's a $3200 part! 😲
LadyRancher
Kabota L3010
Aug 16, 2024
Arizona
It went via semi to Kabota, it was bought from them. Yes, leaking around the purple on your diagram. A regulator? A hyd fluid regulator? It must need a special gasket? It also leaks from the bolt on the center of the "regulator"
LadyRancher
Kabota L3010
Aug 16, 2024
Arizona
I appreciate you found a diagram! Their top tech sure couldn't. Now, where can I get that gasket and center bolt? Huge thanks! Some jerk sabotaged my tractor.
7,488
Please for the love of KUBOTA, quit calling it a Kabota! :ROFLMAO: :ROFLMAO: :ROFLMAO:
7,488
It's not a matter of just replacing the gasket If it's leaking around the nut and bolt.
The regulator needs new seals up in it, and that is a very very intricate job.
It will take a tech with some serious skills to do that on the tractor.
How many dealers are close to you?
