I bought my L4740HSTC used. It came with a subframe snow plow and factory joystick. The joystick is plumbed to the rear remotes. I’m not really a fan of this set up as it prevents me from being able to use the power shoot on a snow blower. This is the only Kubota I’ve seen with this hydro setup. Could someone lead me to a link of what it would take to hook the joystick up to the normal power beyond location and then I could install the factory levers to run the rear remotes. Apparently my tractor doesn’t have the normal manifold that’s used with the joystick. Thank you
