John Deere front implement mount
2manybikes
19 L3560 HST with cab.
Aug 2, 2021
58
32
SW Va.
I've had my JD for about 6 years and never had the bucket off. Thought it might be nice to use some of the SSQA implements from the Kubota on it. Can someone recommend whatever adapter they have used, or are using that mounts to the JD system and allows the SSQA attachments to be mounted? Just homeowner/light farming use.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
I've had my JD for about 6 years and never had the bucket off. Thought it might be nice to use some of the SSQA implements from the Kubota on it. Can someone recommend whatever adapter they have used, or are using that mounts to the JD system and allows the SSQA attachments to be mounted? Just homeowner/light farming use. View attachment 72238
Hello 2manybikes,
There are a few vendors who make this adapter. Pallet forks Inc. for one. It is even listed on Amazon. Be prepared to lose some small amount of capacity because you are pushing the load center further out front.
Good luck with it, and have a good 2022.
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
318
104
Nicollet, mn
John Deere actually has an adapter available. I have one for my 2032R. It has levers and works well. Take a look at it before you buy something else
2manybikes
Aug 2, 2021
58
32
SW Va.
Tx Jim, 19thSF and Kurtee, thanks for responding. I will look into all of the suggestions.
