Is there a fuel tank filter or screen
haanzel
L2600DT, G4200 mower
Jul 30, 2014
125
My l2500 runs for about 15 minutes before it starts running poorly. I have traced it to a fuel issue. Replaced the filter but there appears to be some junk/rust in the tank. Is there a screen or filter besides the fuel filter that would be blocking this?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,046
Williamstown Ontario Canada
No tank screen is mentioned in the WSM. I do not see one on the Messicks parts illustration.
However, crap can still block or restrict the tank outlet.
Dave
9,089
Nope just a pipe off the tank, some of the inlets of the filter housings have an inlet screen. ;)
haanzel
Jul 30, 2014
125
Is there a way to clean it out without pulling the tank? I used some older biodiesel and think some mold/algae had it's way.
haanzel
Jul 30, 2014
125
What I think is occurring is it runs fine initially because the particles are all over, but after 15 minutes or so, there is enough of the that cause the blockage. Hence the question about a screen. I can change the filters a couple times and see if that helps.
9,089
If it is possibly algae, treat the fuel in the tank with biocide.
But if it other debris, the only thing that really going to fix properly and completely, it is pull the tank and remove the debris! ;)
shootem604
Apr 23, 2018
874
British Columbia
Does anyone know if the Kubota Fuel Tank Strainer, Part # 13251-41060 for the older B series fits well into the neck of any other Kubota tractor tanks?
