Is greasing every 10 hrs enough?
BAP
Dec 31, 2012
3,221
1,326
Put on. Lincoln Auto Lube system like many excavation equipment and farm equipment like self propelled forage harvesters use. It will automatically keep your machine greased all day long.
BX23-S,57 A-C D-14,
6,345
I found out the hard way that '10 hours' is too long to regrease the pins on the BX23S stabilizer legs at the 'frame' end ! While the lower ones( foot pad) were fine, the 4 others seized up. Hint: take rear wheels off to make it easier to whack out the pins. They're about $200 CDN to replace or 8 hours to refurbish.
chris142
B7510
Jan 4, 2026
104
53
Apple valley,ca
I worked for a company that had some equipment with those on them. They never worked right. They had me take those off and install zerks.
whatsupdoc
L3302
Jul 9, 2024
186
215
I grease my excavator every day my tractor depending on how its used, mostly used for mowing so
yea.
What I do different is I grease at he end of the day when all the joints are warm and so when I need to use
it its ready do go especially on cold mornings.
chris142
B7510
Jan 4, 2026
104
53
Apple valley,ca
I grease it with the CORRECT GREASE approx every “Quarter”…but I only put about 30 hrs a year on it.
(For comparison, My industrial road-compactor-roller calls for weely on a few things and 100 hrs or monthly on most. But that machine was designed for daily use by paving-contractors and I use it only about 30 hrs/yr ….maybe 3 or 4 times for a half-day-long job to compact my turf-runway to keep hogs off it……so I only grease it bi-annually…spring and fall.)
What is the “correct” grease? Pay attention to that. Do not mix different types. Find out what your equipt needs…thoroughly grease it (to remove or replace whatever was in there)…then use the same grease as specified.
This is most likely “General Purpose Chassis/Wheel-bearing No. 2” .and the most common is Lithium-based …(although some folks have a strong preference for synthetic…and well-respected ones are
”Lucas Red and Tacky” or “Mystic JT-6”. (I use Pennzoil 707L Red Wheel Bearing & Chassis Grease, an NLGI Grade 2 lithium complex grease (petroleum base, 500°F dropping point, NLGI GC-LB rated for marine use because it resists water-washout such as on boat trailer sheel bearings, on most things I own. I chose that grease because it was highly-rated and was sold at a favorable price by the case w/free delivery, so I stocked-up.)
’BUT…for your loader and things such as pins and bushings…use a “Moly” type grease. (2% minimum) becuase it‘s better on things that “slide” and don’t have roller or ball bearings. (Do NOT use “Moly” on roller or ball bearings because it may allow them to slide rather than roll.)
Do Not Mix different type greases. That’s why it’s a good idea to make a choice, buy a quantity, and stick with it. Different types can conflict with each other and cause bearing/bushing failure.
Here’s a concise info sheet and compatibility chart : https://www.fluidlife.com/resource-...Yye_do8MV8Eh-Vkw9mMHAwR0nvwtFqFjWbsUtoPV07MmJ
Hope this helps.
I'm using a lithium grease with 3% moly. I know not to mix grease bases. In the past I tried red and tacky in the ball joints on my wife's car. Greased ever 5000 miles and the ball joints didnt last 30000 miles. Btw lucas recently changed the grease base. The new plastic tubes are different base.
