Is greasing every 10 hrs enough?
BergyPatty37
Kubota L355-SS w/L1720 Loader
Jun 14, 2026
71
20
Maine
Won't hurt anything, other than spending more on grease and time greasing. Id stick to the 10 but if it makes you feel better doing every 5 go ahead.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,017
2,383
Western MT
I think 10 is an approximation just in case. They don't know how you will use your tractor. 5 hours won't hurt anything.
JasonW
932
642
Al
I’ll do mine every day if I’m working it for the day. Tractor and excavator. Just using the tractor around the house I don’t keep track of hours because depending what I’m doing I might not use the loader.
With that said grease as much as you like, all the excess will just get pushed out of the pins anyway. If you grease regularly any it should only take one or two pumps on each pin.
The saying is grease is cheaper pins is correct but I’ve seen people go way overboard on grease.
GrumpyFarmer
5,331
I don't think so. When I use my Kubota it gets beat up on rocks. It gets tossed around pretty badly. Thinking every 5 hrs better.cant hurt right?
How does the machine getting beat up by rocks and tossed around affect the need fresh grease?
I don’t think anything wrong at all with more frequent lubrication, but at ten hours of use, there most likely is still grease that is functioning just fine in the joints.
7,747
If your concern is the life of your tractor, thinking more grease will extend usage, probably best to treat it like a tractor. Beating it up on rocks, sounds like you are using the wrong machine.
7,486
Excavating equipment is greased once a day and the operating conditions are far harsher and more demanding than anything your little tractor sees. If every 5 hours makes you feel better grease away but dont deceive yourself - you arent extending equipment life in the slightest.
chris142
B7510
Jan 4, 2026
103
53
Apple valley,ca
I actually enjoy doing basic maintenance. It makes all my problems go away( temporarily anyway). I do NOT enjoy pulling engines or chasing electrical problems. Thats for the birds
Trash Panda
L2501
Feb 18, 2022
314
288
Wyoming
10hr greasing intervals are likely far exceeding the needs of your tractor.
Actual hard-money earthmoving equipment run on a similar schedule, and it’s plenty for them.
5hr intervals won’t accomplish anything besides burning up more perfectly good grease.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,502
708
Richmond, Virginia
Like everything... it depends. You rarely can over grease, you certainly can under grease.
If I am digging sandy gritty dirt, more often, if I am scooping up gravel/rocks or mulch. less often.
I think about the debris getting into pivot points.
Trash Panda
L2501
Feb 18, 2022
314
288
Wyoming
I like your style, these other guys are making me feel bad.
:LOL: :LOL:
Meh.
I’ve got a fleet of equipment that I’m responsible for, that see harder use on the daily than any tractor does. I understand that most people here run their machines as a hobby, and thus have a hyper-conservative view on maintenance.
Daily (8-14hr) intervals have resulted in zero problems or unnecessary wear on anything thus far in my experience.
netspyder
L3010HST
Jun 9, 2025
52
92
Missouri
i don't track hours - beyond regular maintenance. i grease all the things at the beginning of the day whether i ran it for 2 hours or 16 the day before. i'm def not going to stop in the middle of a project to hit the zerks with a lil grease.
4,320
I grease it with the CORRECT GREASE approx every “Quarter”…but I only put about 30 hrs a year on it.
(For comparison, My industrial road-compactor-roller calls for weely on a few things and 100 hrs or monthly on most. But that machine was designed for daily use by paving-contractors and I use it only about 30 hrs/yr ….maybe 3 or 4 times for a half-day-long job to compact my turf-runway to keep hogs off it……so I only grease it bi-annually…spring and fall.)
What is the “correct” grease? Pay attention to that. Do not mix different types. Find out what your equipt needs…thoroughly grease it (to remove or replace whatever was in there)…then use the same grease as specified.
This is most likely “General Purpose Chassis/Wheel-bearing No. 2” .and the most common is Lithium-based …(although some folks have a strong preference for synthetic…and well-respected ones are
”Lucas Red and Tacky” or “Mystic JT-6”. (I use Pennzoil 707L Red Wheel Bearing & Chassis Grease, an NLGI Grade 2 lithium complex grease (petroleum base, 500°F dropping point, NLGI GC-LB rated for marine use because it resists water-washout such as on boat trailer sheel bearings, on most things I own. I chose that grease because it was highly-rated and was sold at a favorable price by the case w/free delivery, so I stocked-up.)
’BUT…for your loader and things such as pins and bushings…use a “Moly” type grease. (2% minimum) becuase it‘s better on things that “slide” and don’t have roller or ball bearings. (Do NOT use “Moly” on roller or ball bearings because it may allow them to slide rather than roll.)
Do Not Mix different type greases. That’s why it’s a good idea to make a choice, buy a quantity, and stick with it. Different types can conflict with each other and cause bearing/bushing failure.
Here’s a concise info sheet and compatibility chart : https://www.fluidlife.com/resource-...Yye_do8MV8Eh-Vkw9mMHAwR0nvwtFqFjWbsUtoPV07MmJ
Hope this helps.
5,719
I pretty much "wing it".
I won't grease my BH at the "exactly the 10 hour mark" if I haven't used it in those 10 hours. That to me seems a wee bit overkill, not necessarily "bad", just a little overkill. 😉
But if I'm digging a trench with it,.....Well then, yea sure, it gets greased.....and probably before the 10 hour mark.
