Instrument panel
2,881
Murphy panels are common in industrial settings to monitor systems and transmit information signals to control rooms.
They are high quality as far as I know but probably expensive. But it should be able to protect your engine when you aren’t around it to see it getting hot/losing oil pressure…
I am assuming that is what you are getting from Murphy = protection and visual display not just display.
Floridaman
38
Florida
correct I just need it to be able to view the Pressure and if for some reason, something goes south on the engine it’ll turn it off if I’m not around.
