I assume you have a pin on loader. That will be your biggest challenge. A valve is easy and cheap.Has anyone had any experience or advice on installing a grapple on an older tractor (2005 B7510)
I realize I will have to source a valve body somewhere.
But I think it would be a lot better than forks.
Just checking.
Thank you.
I have both and the forks will hold a lot. the grapple is great for moving brush a longer distance and moving piles of logs to keep them out the dirt also better for rocks you can even pull large rocks out of the backhoe spoil as a sort of a screening process. but I am using the forks more than the grapple.re: 'better than forks'
That depends on what the task is, the material and you.
Generally speaking a 'grapple' is supposed to be used to 'hold' a big wad of material, forks are like only having the lower 1/2 of a grapple.
I have the HLA 900# forks on my BX23S. After a few days it was surprising how much 'stuff' they can carry, since the loader rotates back a long way. If you 'load' them right, the 'stuff' doesn't fall off unless you drive crazy fast over bumpy ground.
Last week I saw that there's is a grapple for the BX23S at the dealer. While it would be a nice addition, I've moved mountains of stuff without it for the past 4 years, so I'll save my coins for something else.
I do recommend SSQA if you don't have it. While swapping 4 pin bucket for forks may be fun for you now, it won't be in the future ! No matter how old we get, we're not getting younger !
I honked the horn warning the shed I was coming and it just wouldn't move out of the way.Grapples are very handy to have, but it is a shame that you ran into your shed with it! View attachment 93563
Old and tired. Thanks for the advice.They have always been very "proud" of grapples... Personally, I don't ever see prices going down ever. This is the new normal. If you think you want a grapple sometime in the future, get it now.
I read all the time about how new grapple owners wish they had gotten it sooner... I would not be able to afford a grapple now just like I couldn't afford it then. It's going to sting whenever you decide to buy... I don't feel my sting anymore.
I bought parts here and there... and saved up to buy more parts. Learned how hydraulics worked and did the work myself. Took about a year to get my setup done. I did get lucky and bought my grapple used....
Heres a drawing from the LA352 loader parts list. If that's how your loader is connected, someone on here can fix you up.Old and tired. Thanks for the advice.
I have a set of bucket forks that I think would work great with a grapple. It looks like I may have to custom make it. I would still be curious about hooking up the hydraulics. I have basic knowledge of hydraulics, I just don’t know where to tie in.
You just insert the valve for the grapple into the existing power beyond circuit coming from the loader valve.Old and tired. Thanks for the advice.
Is your loader LA352? Do you have a valve that you plan to use?...It looks like I may have to custom make it. I would still be curious about hooking up the hydraulics. I have basic knowledge of hydraulics, I just don’t know where to tie in.
Hello againIs your loader LA352? Do you have a valve that you plan to use?
First question to ask yourself, do you only need a valve for a grapple? (and not, 3 valves for Top and Tilt hydraulics also???) It's pretty easy to add them now.
If I only wanted 1 valve for a grapple, I would look at this valve https://www.surpluscenter.com/Hydra...e-Wolverine-by-Prince-Mfg-MB11B5C1-9-7861.axd
What Kubota tractors use are "Open Center" hydraulics with power beyond. (Power beyond normally requires a plug to be inserted into the vale body.) Open Center uses 3 lines (other than the working ports) to make the valve work; IN port, high pressure out port (called power beyond) and the low pressure, return to tank hose (this is the only line that can be "T'ed" together).
You can look at cheaper Summit valves, but I have not dealt with them... in the link above there are instructions for installing the valve. See if they make sense... (or read my next part...)
What I did, was I mounted a valve above the FEL control (take off the plastic cover if you have one and use the holes to mount a plate to mount the new valve). Identify the power beyond hose of the FEL and hooked it up to the power beyond port of the new valve.
Then buy a hose to go from the old power beyond of the FEL to the IN port of the new valve. That completes the circle of power. Only thing left is to "T" the two, return to tank lines together.
It took me a long time to understand what's going on with hydraulics... so feel free to ask more questions if you don't understand something and we'll try to make it as clear as mud...
Electric or manual valve? Electric valve operated with a button on the joystick is usually prefered for a grapple but manual vakve next to joystick is a lot cheaper.Hello again
My loader is a LA304
Yes if I understand you right I would like to add a valve for the grapple. That would give me a cylinder that I could use for the grapple?? Right?
I do have the single lever for tilt and boom up and down.
Thanks again.
I was wanting a manual valve. I am not a fan of the electric ones.Electric or manual valve? Electric valve operated with a button on the joystick is usually prefered for a grapple but manual vakve next to joystick is a lot cheaper.
Dsn
A single spool manual valve is easy and inexpensive. This is specifically designed for the standard L series but the concept works for just about any recent Kubota with an open loader station. Just have to tweak the hose lengths and mounting bracket.I was wanting a manual valve. I am not a fan of the electric ones.
