Installation Help - LA302 on a B7510
thecanuck
Indiana
Could use some advice/assistance on the installation of a LA302 on my B7510. I bought my B7510 about 4 months ago and came without the loader attachment from the factory and just has the mower deck installed. Recently purchased an LA302 off of a dead B7510. Have all the arms/hoses that came off the dead B7510. Do I need any additional hydraulic parts? Any advice/recommendations? I was planning on pulling my mower deck and brackets off this weekend and beginning the process of getting the hardware installed. Will be buying a couple gallons of hydraulic fluid to add to the system. Thanks in advance for any help/advice!
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
You can download the LA302 installation manual BY CLICKING HERE .
Hopefully you got everything you need with it.
9,138
Do you have the 3 lines that feed the valve?
Did you also get the adapter plate for the hydraulics?
thecanuck
Indiana
Yes - i have the 3 lines that feed the valve.
The adapter plate I got splits it into two male hose attachments.
When I worked with him to disconnect it I noticed one hose goes under the seat and two go to the adapter plate right underneath the tractor...
thecanuck
Indiana
So it looks like the only thing I didn't get was the return fitting that goes into the side of the transmission - i have the hose - just no the fitting? Is that something that could be sourced locally? Wondering if I can match the threads and get a fitting at NAPA?
5,501
2,208
Yes that's a common sized fitting. JIC male to I think NPT male, but remove the plug in the case and check the threads. I forget the actual sizes but it's a common fitting.
One caution...don't overtighten it ;)
9,138
It's not a JIC to BSPT like the rest of kubota's odd fittings?
wgator
Jul 28, 2018
482
147
NC
The Kubota P/N for that fitting is 75582-66810. Might be able to get it from Kubota dealer.
