ScottHam
Kubota L3560HST-LE 4WD; R4 tires; Armstrong Ag BRG-mini grapple; 1272 box blade
Here is another question in connection with my upcoming purchase of a Kubota 2501HST with FEL and 3rd function valve. I'm planning for R4 tires and rear wheel spacers. The primary intended use for my tractor is brush clearing and road maintenance. My property here in the Texas hill country is rocky and hilly, and my half-mile driveway is narrow and curvy and fairly steep in some places. The steep places are paved, and the rest is caliche/gravel/dirt. The brush consists of juniper/cedar bushes/trees including little saplings up to ~16-inch trunks.
Implement considerations:
Grapple - I've already received some excellent advice regarding types of grapples and their uses. Thank you to all who have commented.
Rear blade vs box blade - Given how curvy and hilly my driveway is, I'm leaning toward a rear blade because it seems like it will better pull the gravel back onto the road, but I am open to suggestions.
Tooth bar - I'm certainly going to be doing some digging in this rocky ground, and also hoping to tear out some saplings and bushes. Based on videos and comments I have seen the Piranha toothbar seems excellent for this sort of thing, but perhaps traditional teeth attached to my bucket is better.
Weights - I plan to get my rear tires filled, and will likely keep the rear blade on for additional rear weight......Not sure if I want to also get wheel weights or a ballast box.
Any comments or suggestions are very welcome. Thank you.
