Information request
dwight1944
ZD21
Jul 12, 2023
ohio
I see that it seems this is dedicated to tractors.
Have you branched off . . . or thought of branching off to pick up the orange mowers?
Reason? I got one . . . every now and then need some help / advice on making the little diesel 60 in zero turn do its thing.
Thanks, may God bless,
Dwight
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
Nope-This forum is NOT dedicated to tractors, though most of the posts are of tractors.
If you look harder, you'll see many many posts about Kubota mowers and even some about excavators.
2,551
This forum is about Kubota and all the machines that have Kubota engines/parts that are in those machines.
Ask your question about your ZD21 and we will be glad to help
dwight1944
ZD21
Jul 12, 2023
ohio
Is it a "normal" thing for the mower gear box to go bad?? There are several videos out there on fixing the darn things . . . mine went belly up for the second time in 4 years.
Plus the 3 cyl diesel just jumped up all of a sudden and is a pain in the neck to get started. Used to be, one full turn . . . it was running . . . now it is lucky to start on number 15.
Any ideas??
May God bless,
Dwight
2,551
Any ideas??
May God bless,
Dwight
On the starting part - you glowing the plugs as usual?
Have you changed the fuel filters at all?
Workerbee
Zd21
Mar 1, 2020
204
91
MN
Ive had a zd21 since they came out around 18 years now, and have never had any gearbox issues. I have had algae in the tank and filters which caused poor starting and running issues, but a thourough cleaning of the tank, and two new filters cured that.
dwight1944
ZD21
Jul 12, 2023
ohio
Haven't changed anything in the routine . . . but might look at the filter . . . honestly didn't know there was one . . . will have to "dig" in and see what I can find. Thanks . .
May God bless,
Dwight
