idle speed
spurrowl
10
sealy texas
thanks, something happen as i had finished shreading and came in for lunch and when i went back out and started the tractor it was runnng 2000 rpm's and i could not lower it, i think something under the hood on the throttle is the problem
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
40 series is the last of DPF free I believe.
Id check throttle linkage and make sure something didnt vibrate loose.
spurrowl
10
sealy texas
i found the problem the throttle rod has slipped and is to long not letting it reb down under 1500 rpm's so now what i do not know is do i adjust it under the dash or under the hood
6,274
It looks like the adjustment is under the dash. ;)
