I have found some more tools for the B6000.
Rob
B6000DT / B7100DP /B8200DT/L225/Globe PTO Chipper/Lewis Backhoe/huxley TR66
Nov 22, 2009
679
9
Leafy England....
Hi guys
I 'm allways on the lookout for some little extras for my B6000 and i have found two cracking bits this week.:D:D
Now it may come as a bit of a surprise to you guys in USA, Canada & Australia etc but there does appear to be a much bigger following of all things tractor & orange where you all are than there is in the UK, not sure why, but thats just how it is for some strange reason.:confused::(
Anyway, I'm a big fan of all things kubota, well lots of earth moving stuff to be honest, spent some time a few years back using an Ackerman H7, really smoooth bit of kit.:cool:
Sorry about that drifting of topic ;),back to the subject matter, by sheer luck when i was collecting something else that I also aquired a genuine kubota B6000 front dozer blade complete with the lift ram etc.
This is not the version that fits under the tractor chassis but the proper dozer blade that fits onto the outsides of the loader subframe, the arms of the blade goes around the outside of the front wheels, just like a proper dozer seup.
now then, i have the K450B loader and subframe designed for the B6000 fitted and have been tyring to workout for sometime now what the 2 holes were for , one on eitherside of the subframe on the lower edge beneath the loader upstands.
And now i know, its for the dozer blade, just slide a pin into each side and that is the rear mounts fitted.
It was a real find for me as i have never seen one fitted over here, let alone one for sale with or without a tractor, it needs a small amount of work but only surface stuff, i'll put some pics up later on.
so for all you guys with the same loader subframe,also wondering what goes there, thats what the holes are for.
the other bit of kit is a heavy duty water pump 3" inlet and outlets powered from the rear pto, and fitted to a custom made framework which bolts to the rear end , it will be getting some serious useage also.
anyway , if anyone else has any pics details of there B6000 with a dozer blade etc fitted or anyother items , please put some pics up.:D
thanks
Rob
