i have a tg 1860 lawn tractor , how do you adjust the neutral system as the tractor does not go back to neutral when i reverse and slowly moves back to neutral when going foward, also i need to replace the pto switch so how do you remove it with out breaking it in case i just need to clean the electric connection, some times it comes on then you have to pull it eight or ten time to get it to come on thanks
