HYDRO FILTER CHANGE
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
LX2610 Headed for the 50 hr hydro filter change. Never heard for a filter change with out an oil change but what do I know? Anyway, When I take the 2 filters off can I expect a big or small fluid loss or none?
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
540
302
Mandeville Louisiana
Not sure if you have a FEL but when I needed to change fluid filters on my MX5100, I lifted the front end with the FEL ,put blocks under the front wheels, had brakes on and lost just a little when replacing filters.
Frankb
Kubota B2601, FEL, Backhoe, Belly Mower, Grapple, Rear Scrape Blade
Apr 3, 2011
239
66
Person County NC
I used a shop vac to create a small suction at the fill port and lost less than a cup while changing both filters and took my time taking off and putting on. The loss I experienced was the fluid in the filters themselves. Thanks to others for posting that tip and videos. Works great.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,381
385
It's your investment, but I know I dump the break in oil. You might be surprised what it looks like.
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
Yes, but it is 4 gallons, right? Which is a lot, especially for todays has-mat restrictions. Kubota seems concerned about the life of their tractors so maybe this is cooked into their calculations. I have seen few companies for instance that tell you to warm up engine for 5 minutes. This benefits Kubota and their rep as an engine brought up to operating temp before being used will outlast cold run engines 3 or 4 or more to 1.
