Hydraulics are too fast, or Im too slow
Dec 9, 2024
30
20
Idaho
I rented pallet forks to unload something and, wow, thats not like running a fork lift. I could barely touch the curl without sending the load bouncing off the end of the forks. Way faster than I am on the controls. Any way of mitigating that?
I noticed this too on the tilt side of my top and tilt. The curl on the rear is too slow, but the tilt is way fast. Anything I can do smooth things out?
Low throttle, btw
Thanks
Dustball
2016 B2650HSDC
Sep 15, 2023
417
272
Hudson, WI
When moving the stick to the right, you need to go past the detent for more control.
If you want even more speed control, you can install inline flow controls on the hoses or cylinders.
BAP
Dec 31, 2012
2,934
1,045
What are you running for machine? Hard to give you advice without knowing if you are talking about a tractor, skid steer, lawn mower, utv or something else.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,590
1,828
Near Lancaster, PA, USA
If you haven't had a lot of experience operating the hydraulics, maybe it's just a matter of becoming more familiar with them. Try being more gentle with the controls and see if that helps.
old and tired
L2800 HST; 2005; R4
You should be able to feather the valve control body but we don't know what you are running...
If this is for long term usage, I installed a "needle valve" (Cost more than restriction orifice) but are adjustable. To be honest, I set it once and never changed it from the original setting.
Again not knowing your hose size, this is the one I have.... https://www.surpluscenter.com/Hydra...nce-WFC-600-In-Line-Flow-Control-9-7960-6.axd
5,688
YES , operating pallet forks on a tractor is a LOT different than a forklift !!! After 7 years still not smoooooooth using them on my BX23S,especially compared to the A-C 5K forklift I had.
I use my left hand to brace my right , which helps but it's still a BIG 'learning curve'.
Other 'trick' , use the slowest RPM you can to do the operations.
The 'valving' is NOT designed/built the same way as a true forklift.
5,261
Low throttle, btw
Thanks
Yes ypu can adjust flow rate. How you do it depends on your particular needs.
What model tractor and loader?
Is the bucket OK other than the rental forks?
What is "curl" on a top and tilt setup?
What sort of rear remote valves do you have?
