Hydraulic top link for B2410 HSD
ndkubota
B2410 HSD
Mar 21, 2016
Watford City
Is is possible to install a hydraulic top link on my B2410 HSD?
If so can I hook it up to the tractors hydro system or would I need some independent setup?
Detailed explanation would be much appreciated as I am a bit new to this.
thanks in advance!
5,207
1,893
the top link is nothing more than a hydraulic cylinder. So, you will need a way to control hydrualic fluid flow to and from that cylinder. Meaning, a way to put a remote valve on it.
Check your dealer. You will need 3 pieces. # BL7303 (first remote kit), then B7303 (hose kit) and also 6C040-95100 (hardware and fittings to attach the kit to the tractor).
One can also build his or her own remote valve "kit" out of TSC stuff, but trust me, it ends up a nightmare in the long run and only saves about $100 over the Kubota stuff, and with the TSC route, you will have to fabricate EVERYTHING.
ndkubota
B2410 HSD
Mar 21, 2016
Watford City
is there any online schematic or write up on install process?
