Hydraulic top link as snow plow angle actuator?
Cayuga
Kubota BX23S, JD 214
Mar 28, 2021
19
Lansing, NY
Hi,
I have a bx23s and I'm going to be using a 60" UTV snow plow on it and I'm thinking of adding a hydraulic top link as an angle actuator.
Has anyone done this? Any advice (including why I shouldn't)?
Thanks!
Jeff
mikester
M59 TLB
Oct 21, 2017
3,987
2,686
www.divergentstuff.ca
If it works for you go for it. Do you already have the hydraulic top link that you want to re-use? If you are buying something, just get a cylinder that has the bore and stroke you need, might be cheaper than a cylinder made to fit a top link.
Yooper
3901 LA525
May 31, 2015
1,703
865
NE Wisconsin
Sounds like a good idea! Since you are making the mounts they can be located to make use of the stroke to fit whatever angle you want the blade to work at.
4,725
I think it’s a great idea.
I also think a “generic cylinder” would be a less expensive route as well. (unless you already have one…..obviously;))
