I drained the transmission/ hydraulic system oil and removed the strainer to clean it. A few tiny pieces of metal were on the mesh, but that is all. Problem is--it won't screw back in. I get a turn on it and then it gets very stiff. I even tried it w/o the hydraulic pipe banjo fitting--just the strainer all by itself, and it still wouldn't go back in. I do not want to use a wrench until it is nearly tight. I even removed the drain bolt from the opposite of the strainer to make sure it wasn't hitting on that. Threads all look good and no visible debris in the threads on the transmission.
Puzzled.
Puzzled.
