Hydraulic steering lines on BX2200D
TJD
BX2200D
Oct 4, 2017
Oakland MI
Need to replace both Hydraulic steering lines on BX2200D any hints on how to get them off front axle
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Re: Tjd
Besides undoing the hoses from the cylinder, (probably drop the axle to get access to the connections), not sure what you are asking? Why are you replacing them both?
For you next posts, please put a full description in the thread title instead of your username.
whitetiger
Nov 20, 2011
2,942
1,399
Kansas City, KS
There is no reason to remove front axle.
Jack your tractor up under front of frame so you can tip the axle up and down. Just unscrew hoses from fittings.
