Hydraulic Pump
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
Does anyone have a ballpark idea what it would cost to have a hydraulic pump overhauled on a B5200 tractor. The tractor is 34 years old and I had to remove the pump to replace a freeze plug behind it and thought while the pump is off it should be overhauled, especially since I plan to put a front loader back on the tractor.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
395
145
CNY
I wouldn't worry about it unless it is leaking or the hydraulics are slow or weak. It doesn't appear that any parts for that pump are available beyond seals and o-rings.
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
It wasn't leaking around the pump. Years ago the front loader quit working but the problem was with the cylinders and the control valve. I really have no way of knowing if I was loosing pressure at the pump too.
1,415
It won’t cost much for the parts. If you have someone at a hydraulic repair shop do it it may get around the $100 mark total (I am guessing)
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
I believe it's a gear type pump. These work for a LONG time. If it's working and not leaking I wouldn't mess with it. Resealing is one thing. Parts may not be available for a full rebuild.
whitetiger
Nov 20, 2011
2,921
1,383
Kansas City, KS
The only parts are seals or complete pump assembly.
