Hydraulic Pump Help
Snafu51
7200 HST
Jul 10, 2018
Spring, Texas, USA
I need help. I***8217;ve got an old 7200 HST that has probably had an engine swap. It now has a D1105 engine. The hydraulic pump for the front bucket has started leaking into the crankcase. I pulled the pump to rebuild it and I***8217;ve found that it has been modified to allow it to operate in reverse rotation and one of the mounting tabs has been cut off to allow it to be mounted to the injection pump. I***8217;m certain it is the wrong pump for that engine. The installed hydraulic pump part # is 67111-76103. Can anyone help me with the correct part #?
6,359
Post some pictures of what you have on it right now and how they have it set up.
It sounds like you might not be able to put a stock pump back on it.
Snafu51
7200 HST
Jul 10, 2018
Spring, Texas, USA
I did a little research and there has been an engine swap. The engine is from a B7610 and uses a GP081-48L hydraulic pump superseded by 6C140-37304 superseded by 6C140-37309 ($950+ new). The 7200 HST came with a D950 engine.
torch
Jun 10, 2016
2,619
869
Muskoka, Ont.
Nevermind. I thought you were looking for that pump, but on re-reading it, I see that is the one you have and are looking for the correct one.
