Hydraulic pressure bump up options
jyoutz
Jan 14, 2019
3,003
2,048
Edgewood, New Mexico
And allow for more lift capacity than the tractor weight is designed for. More tractor roll overs. Not a great idea.
  • Sad
Oleracer
B2150 Kubota LA 350 750 Woods S250 Bobcat 300x deere
Jul 18, 2024
201
238
CT
These adjustment shims will help bump up the pressure and bring back the muscle to your machine!
Use code MOREPOWER10 to receive 10% off!!
JailBreakYourTractor.com
Oh boy your gonna get hate from the ROPs, ether , hydraulic police 🤣. Looks good . Factory spec will always be on the low side.
Oleracer
Jul 18, 2024
201
238
CT
Do you guys also sell broken front axle fix-it kits?
I bet more like front tire explosions 🤣 Lets see those broken front axles from bumping pressure 200-500lbs😎.
mcmxi
6,412
NW Montana
You do realize Kubota themselves sells shims...
Do you have a link to a such a kit sold by Kubota?
Neil Messick made a video about this.
jyoutz
Jan 14, 2019
3,003
2,048
Do you have a link to a such a kit sold be Kubota?
Thanks for the post. Good information and not surprising to me.
MOOTS
MX6000
Jun 27, 2019
1,928
2,212
Canton, Georgia
I purchased shims from my dealer and a gauge from @Kennyd4110 when I bumped my pressure. Ended up not needing the shims, just tightened the valve a bit. That got me near the higher recommended range, I forget the exact number.
BAP
Dec 31, 2012
2,763
876
BXExpanded sells the kits with shims and gauge for $35 less and has for years.
mikester
M59 TLB
Oct 21, 2017
3,570
2,049
www.divergentstuff.ca
Genuine customer review of our L/MX- Series kit:
Cool! I really enjoyed more hands on time with my tractor pulling the cab so I could replace the main steel hydraulic line after it split lifting rocks at my max loader capacity. If I bump up the pressure I can do this more often! Maybe next time I will let the dealer fix it so they can keep my machine in their shop for 2 weeks to replace a $300 part and charge me $5-10K labour.
5,607
Wow, what a job!
mcmxi
6,412
NW Montana
Does Kubota sell shim kits to do what you did, i.e. get the pressure within factory specs, or do they sell them so that customers can raise the pressure above factory specs like the kits found on eBay and other online vendors?
JailBreak Your Tractor
Vendor Member
BX25D
Nov 26, 2024
31
Ozarks
jailbreakyourtractor.com
I have NO IDEA why people assume these kits are all about boosting your pressure ABOVE factory specs.. we have NEVER promoted that! The point of the kit is to make sure you get the maximum performance that your machine is DESIGNED for... most machines are never adjusted/checked at the dealer before delivery.. additionally over time the spring in the hydraulic pump weakens and adjustments are part of the maintenance.. not sure why some people don't understand this.
Vendor Member
BX25D
Nov 26, 2024
31
Ozarks
Use common sense in all things.
jyoutz
Jan 14, 2019
3,003
2,048
Bec
Because you advertise a 25% boost.
MOOTS
MX6000
Jun 27, 2019
1,928
2,212
Canton, Georgia
Yes and also probably yes. Need to know what you are doing before you do it. It’s not an unbolt, toss in a handful of shims and reinstall type deal.
Shims are sold individually from .1, .2 and .4 there may be more. When I did mine I was within specs, though on the lower end. I didn’t add any shims, simply got another wrench flat or so out of the valve body, which was still in torque spec. I probably could have added the .1 and tightened normally.
