Hydraulic Oil Leaks To Engine
tapodaca@earthlink.net
L48TLB Tractor Loader backhoe
Aug 27, 2010
El Paso, Texas USA
I have an L48 TLB. I recently replaced the seals on the hydraulic pump located on the fuel injector. The shaft seal gave out. This allowed hydraulic oil to leak to the engine. After the repair, I used the tractor for about four hour one day and another four hours the next day. The shaft seal went out again. Anyone know what can be causing this? It seams the seals experience a lot of heat. The pump seals look brittle.
Thanks in advance for your help.
