I needed a mounting bracket for my cabbed L6060 as attaching my 2x multiplier to the existing remotes resulted in the bracket for the remotes bending due to the weight of the multiplier with hoses attached(easily fixed with an anvil and a sledgehammer). Came up with this design utilizing 3/8 x 1.5" flat bar steel for the main bracket and 0.25 x 1" flat bar+0.5 x 0.5 steel bar for the rear brace. Also used a 3/8 x 1.5" piece of aluminum flat bar as a spacer between the bracket and the multiplier.
The concept would probably apply to other cabbed models like the M-series with adjustments. It does involve doing a bit of Mig welding, but I'm certainly not an expert at that and things seem to be holding up and everything seems to work.
