I have a L3540 with loader and backhoe attachments. Was using backhoe this morning to dig stumps out and after moving tractor i noticed a puddle of hydraulic oil and a trail. I looked under the tractor and saw a stream of hydraulic oil coming from under the tractor. I dont know how to describe the place it was coming from the most other than to call it what looks like a drain plug with a rivet in the center that can be pushed in and out. I'm assuming this is a weaphoe for over pressure?
It also had a pretty good drip from the front drive shaft or what looks like it should be the front drove shaft that goes between the engine oil pan, about 6 or so inches to the front of this main leak. That was also hydraulic oil, and hoping that is was just coming from the same source...
I took pictures and hope someone can help me out.
1st and 2nd pics are going to be from under cab facing front of tractor
3rd is going to be same area but 6 or so inches forward on the front driveshaft.
4th is under front axel to rear of tractor on front driveshaft
Thanks in advance!!!
Bud
Edit: Sorry the photos are sideways, they are good untill I upload them and then they rotate.
Bud
