Okay, maybe I'm over thinking this but not finding any clear info. Just got a deal on a smallish Ansung backhoe to occasionally go on my M5040 for some light digging work. Manual for the backhoe says:
"The correct method for the particular tractor will depend on the remote couplers available, whether a loader valve or other accessory valve is connected to the tractor system,and whether the tractor has an open-center system(constant pumping of oil to control valve and back to reservoir) or a closed-center system (no flow of oil until there is a demand at one hydraulic cylinder). The four hook up methods are described below. IMPORTANT: Follow instructions carefully when connecting backhoe to tractor hydraulic system."
But then does not go on to describe the methods. My plan was to use the rear remote for supply and tee into the sump line for return. Is this correct? It's not going to be on the tractor too often, so just looking for a basic setup that will work without getting too elaborate.
Currently, the pump directly feeds the FEL valve, and the remotes/3 point hitch are fed off the power beyond port on the FEL valve.
