Hydraulic Help
Tracey
M4700
May 10, 2012
Terry, Mississippi
I need help finding where it is that you check your hydraulic levels as well as where to drain the hydraulic system. Can anyone help me? I have been under it from one end to the other, followed the lines every which way and can not find anywhere to check the level or drain it out. I have a M4700. I am not by any means a tractor mechanic but I am not incapable of doing some simple service procedures myself. I thought this would be one of those simple procedures-but I am stumped.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Not exactly sure on your model. My 9000 has a dip stick at the 3pt lift for the hyd oil. Some will just have a site glass on the tranny.
Drain plugs, probably has 3 or 4 of them. Most likely one right under the floor board on the bottom of your tranny. Maybe one where your front drive shaft comes out of the rear end and probably 2 on the lowest part of the rearend on either side.
OLD GAR
MF210, FORD 8N, BIG TEX CH18,
Aug 3, 2015
69
ZWOLLE
Old thread but.... the dipstick for checking hyd fluid level is on the floor, just forward of the seat, below the 3-point control knob.
