Hello,
I am wanting to hook up my new-to-me FEL to my B2150 and neither I nor the dealer (?!) can figure out what fittings I need to replace the plugs in my hydraulic block so I can actually use those ports. It appears the best/factory solution was banjo fittings, but the pipes are discontinued - I can deal with that, but need the right fitting to go in the hydraulic block. I read this morning that the threads are likely BSPP, but I know nothing else about the fitting, like how long it should be. Does anyone have a part number or dimensions for these banjo bolts? Is there additional weirdness going on in there beyond being a normal banjo fitting?
Here's a picture I snagged from Google, that actually came from this site which shows what part of the tractor I'm talking about. I want to buy A, B, Sump fittings. Part number for the existing plugs is 67810-37890.
