hst wire connector
burrisjason
kubota l5740
Jan 23, 2023
arkansas
i have a l5740 that the wire going to the high/low solenoid got broke and pulled out. it is on the left side of the tractor if you are sitting on it. under the floor down by the hydraulic filter. it throws a 92 error code and will only stay in low. i am looking for a replacement pigtail for this but i can't find it anywhere. i am sure other models with a hydrostatic transmission would have the same plug. it is a 2 wire plug but only has 1 wire hooked up.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,235
1,018
Williamstown Ontario Canada
The rear wire harness is $1,250.
Post a photo of the connector.
In the past someone posted a link to a manufacturer's catalogue of Asian connectors
Dave
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,235
1,018
It plugs into this
I found this contact info which may be able to help you.
Agriserv
This is the cover page for their catalogue
Their primary business is making replacement wiring harnesses for older tractors including Kubota's.
The picture of your connector may be able to guide them in supplying you with what you need.
They do not seem to have a web site.
This link is to Sumitomo catalogue which another forum member found useful for the connector he needed.
Sumitomo
I downloaded the catalogue and split into into sections as the forum would not accept the catalogue as one file.
Dave
tbk5
L3710, L3010, ZD1211, RTV900xt, GR2100, lots of 3pt equipment
Sep 24, 2013
181
Central AL
How many wires are there? It may be easier to go to an auto parts store and get weathertight male and female connector pigtails and replace both sides.
200mph
Mar 3, 2017
1,228
61
PA
Someone posted this source for another terminal end used on newer Kubota. Looks like this company offers a good variety, so hopefully they have what you need.
2-Way Kit (corsa-technic.com)
