HST error code 92
kimolosmike
L5740
Dec 21, 2012
Australia
Hello fellow orange fans.
I have a L5740 with 3400 hours. Brilliant tractor for what I do.
It has started to throw up error code 92 (hi-lo solenoid problem) when the hydraulic oil gets hot after about one hour of light work. After it has cooled everything is normal again. Oil is Kubota product and has done 100 hours.
Putting a hand on the hydraulic filters tells me that the temp is about the same as engine oil filter, but of course I don't know if that's normal or too hot.
I'm thinking the problem is something worn in the solenoid, or something else causing temp to rise too high.
Previously this error code has been the result of a stick ripping out the solenoid wire, but wiring is intact. I haven't rejected the possibility that an electrical connection fails with temp then reconnects once temp comes down.
Any thoughts?
Mike
6,438
I would double check the connection.
Then if it's still doing it you could have a bad solenoid that fails when it gets hot.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Ga' day mate. Welcome to the forum.
kimolosmike
L5740
Dec 21, 2012
Australia
Thank you gents.
I sought advice from the dealership but all they could do was read the manual to me (which I have). Pulling the solenoid is a bugger of a job, so it can wait until I have time.
And I bet the Australian price for solenoid is 4X US price.
