how to verify the "ignition timing" on a B6000
ronbourd
b6000, tak tb016
Oct 26, 2015
rimouski quebec canada
I would like to check the "timing" of the fuel pump on my B6000. Can some one help me find the right way to check if the fuel delivery is at the "perfect place".Thank you for your help! Ronald.
CountryBumkin
Sep 27, 2015
568
Central FL
The general method is this:
You remove the fuel injector line going to #1 cylinder.
Put the throttle in full fuel position. MAke sure fuel cut/shutoff is open (fuel can flow).
Rotate the engine by hand until fuel is just seen at the top of the injection pump for cyl #1.
Then look at the timing marks on the flywheel. It should be at 26 BTDC for your engine.
If it is wrong, the adjustment is made with shims between pump body and engine.
